Salta al contenuto principale
La Casio fx-9750GII è una calcolatrice grafica venduta da Casio. Identificata dal titolo "fx-9750GII" nell'angolo in alto a destra della faccia anteriore della calcolatrice.
Why are my function keys not working properly?
My function keys are not working properly.
In Run-Math program, if I press F1, nothing happens. If I press F2, it opens a list of options in the botton (LIST, MAT, CPLX, CALC, STAT). If I press F3 it opens another list of options (V-WIN, FACT, STAT, GRPH, DYNA). If I press F4, it acts as going into the previous screen (For example, If I am in Run-math and I was in the menu before, it goes to the menu and if I press it again it goes back to the Run-math). F5 acts as the Left arrow key in text editors. F6 acts as moving back a line (selecting the previous line).
Every other button work as intended.
I tried to reset the system through the menu, but since the function keys aren’t working properly, I can’t select the reset option. I’ve also tried the small button on the back of the calculator, but it doesn’t do much.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Hello Ricardo, did you maybe had a spill onto the keyboard?, also if the unit is old, ( i don’t know how old) some buttons might stop working , like buttons of tv remotes, it might be worth it to open the whole thing to have a look if its dirty or worn out . if its worn out, there is a conductive glue available from specialised electronic shops, just cover the tip of the missing carbon rubber with a very thin layer of the conductive glue , wait for it to dry, reassemble. also while you have it open, maybe then you can check if bridging corresponding pad of the reset option would do anything. good luck.
Punteggio 0
Try to redownload the program. I had the same issues and it helped me. It gave me a lot of problems because I used it for education. Fortunately, this site https://plainmath.net/textbooks/ saves me from failing lessons. But maybe someone has other more smart suggestions?
Punteggio 0
Aggiungi la tua risposta
Ricardo OKay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,162
