Salta al contenuto principale
The General Speedrooter 92R Drain Cleaner is an auto-feed drain cleaner 100' x 5/8" from General Pipe Cleaners. Released in 2010. Model number: HDPS92EO.
rescue a 5/8 cable
I have a 100’ drain snake that kinked about 15’ in from the tip, so I cut the cable back and used a quick fix to replace the end. Is there a way I can connect 2 cables together to replace the piece I cut off? rather then replacing the whole cable.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
General Pipe cleaners has a "Quick-Fix" tip replacement you can purchase.
Punteggio 1
Aggiungi la tua risposta
JT Hess sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 395
