Salta al contenuto principale
Guide di riparazione e informazioni sullo smontaggio per il MacBook Pro da 16 pollici rilasciato nell'ottobre del 2021, dotato di SoC M1 Pro e M1 Max progettati da Apple. Modello A2485.
Scratch on body - repairable?
I noticed yesterday I somehow have made a deepish scratch on the lid of my new M1 MacBook Pro 16”…and kind of sick about it. No clue how I did this either. Are there any repair kits that can fix this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi
Like what James said it’s not really repairable but you can make it look better
By cleaning it with isopropyl alcohol and maby applying a little metal polish made for MacBooks but it will basically just sugar coat it
And if your really brave you could try and tapp the mark out from the inside of the housing however with smaller marks like yours it doesn’t always work!
It’s all worth a shot though!
Punteggio 2
2 Commenti:
Yes, metal polish might help a little but be super careful not to get it on the keyboard or screen.
Unfortunately there would be no way to knock the dent out since the glass and display are fused to the shell. You’d have to get a full top replacement which would be quite expensive
da
Yes
Totally agree
The reason why I said knock the dent out is because I thought it was on the palm rest
da
Unfortunately there is nothing you can do about this :(
I’d just wear it as a battle scar, otherwise you could get a skin or a case to cover it, otherwise just see it as part of your MacBook. After the first scratch, everything else comes a lot easier!
Punteggio 1
Aggiungi la tua risposta
geoff sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 70
Ultimi 30 Giorni: 323
Tutti i Tempi: 13,632
