Salta al contenuto principale
Lanciato il 21 settembre 2018. Modelli A2097, A2098. Disponibile come GSM o CDMA / eSIM o nanoSIM / 64, 256 o 512 GB /Argento, Oro o Grigio Siderale. (Si legge "iPhone 10 S").
Compass functionality not spinning/working
Using either the Compass app for PhoneDoctor app to test the compass functionality and it seems like it is not working. Other functionality does seem to work fine; gyroscope, accelerometer, etc. Done a factory reset, DFU restore, nothing.
What could possibly be the problem? Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Maybe use a sensor data output app to see if the gyro is actually working, if it works, then check magnetometer data.
Punteggio 1
3 Commenti:
The gyro and accelerometer seems to be working fine on a different app, though the magnetometer doesn't seem to be responding to any changes :(
da
@remster9000 I use this app to check sensor data: phyphox
da
Managed to get around for this! So I checked with the app you use and it seems like Acceleration (without g), Gyroscope and Magnetometer doesn't seem to be showing any data.
da
Aggiungi la tua risposta
Remy Stark sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 114
