Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
How To Program iPhone 3G LCD/ LCD Datasheet
This question also appears on the "Discuss" board.
I like working with microcontrollers such as those in the Arduino platform. Now that I've replaced the entire display assembly of an iPhone 3G with a IF137-008-1, I'm left with a perfectly good LCD unit that the customer won't want. Is there a datasheet for the LCD and perhaps even a development type PCB that I can plug it into and play with?
For example can I set this up so an Arduino Mega can send a jpg photo to the LCD with some nice caption text?
Thanks
Bob
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione Prescelta
from some teardown reports I have read, I heard that there are maybe 3 likely manufacturers of the LCD module:
- Toshiba Mobile Display
- Sharp
- Samsung
However I'm not sure if it's easy to find the datasheets for the specific panel, but you may be able to do some digging knowing the makers. I don't know if the manufacturer's part number appears on the panel.
on the other hand, I also read that the iPhone 3G uses a National Semiconductor chip to interface to the LCD display, the LM2512AA Mobile Pixel Link display interface
http://www.national.com/pf/LM/LM2512A.ht...
perhaps you can get a clue from it's data sheet and go from there.
have fun and good luck
Punteggio 1
Aggiungi la tua risposta
cochranb sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 12,938
