Salta al contenuto principale
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Keyboard and trackpad not working
I changed my battery carefully, and after that Keyboard and trackpad stopped working.
This seems to be a common problem and I have spent a lot of time going through all proposed solutions without success.
I did all the boot resets suggested. I bought a replacement flex cable, which didn’t do anything. I then bought a replacement trackpad thinking that was the problem, again with no success.
At this point I am thinking maybe I screwed up the motherboard. I have not replaced the keyboard as I assumed since the new trackpad didn’t work the issue is not the keyboard.
Any suggestions? Computer works fine with bluetooth keyboard and trackpad, but not the built-in ones.
Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
did you follow this guide? Sostituzione batteria Macbook Retina 2015
Did you note the warning?
To avoid logic board damage, when your Macook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable. These accessories are not included with your MacBook, so make sure you have them ready before you begin.
See if that fixes things.
Punteggio 0
1 Commento:
I did not actually. So maybe I fried something. After that initial battery replacement every time I opens the laptop I did do that step, but not the first time.
da
Aggiungi la tua risposta
M S sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 90
