Salta al contenuto principale
Il Mate 20 di Huawei è stato annunciato a ottobre 2018 a Londra. Il modello mondiale HMA-L29 è disponibile con 4 o 6 GB di RAM e 64 o 128 GB di memoria interna. Ha una tripla fotocamera, batteria da 4200 mAh e il sensore impronte digitali sul retro.
Is it possible to replace the charging port?
Is it possible to replace the charging port of my phone since I have problems charging my phone. It has problems with some USB-C cables and I have to tuck them in a very special way, also fast charging doesn't work anymore.
Where can I find replacement parts (and maybe a guide)?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It is possible, but unless you have some experience soldering tiny wires, you may do more damage than good. Lots of shops replace charge ports for alot less than the cost of your phone. If you still want to DIY I’d practice on something else first. You’ll need some tools, so the cost may be no less than just going to a shop unless you already have everything.
As for parts, I usually just buy on Amazon or eBay, but a google search will find plenty of sellers, depending on where you live. partsforrepair.com is a good site for parts too.
Punteggio 3
Aggiungi la tua risposta
Theo Thiedig sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 359
