Salta al contenuto principale
Alternativa ai Joy-Con con licenza ufficiale per Nintendo Switch. Rilasciato a settembre 2019, identificabile dai numeri di modello NSW-182 e NSW-182U.
Is there anything inside the feet that would break being cut off?
Long story short, I love these controllers - but the feet do not feet with the case on the body of the Switch, which I need. Wondering if they can removed without much worry.
Long story short - I want to cut off the two feet on the back so I can still use these controllers.
Questa è una buona domanda?
Punteggio 1
1 Commento:
I also would like to know this.
Has anyone tried this?
da
Aggiungi un commento
1 Risposta
Not sure exactly what you mean by feet, but if you are referring to the pieces circled in red in the picture below my answer would be yes you can likely cut them off. I would recommend completely disassembling the controllers and using a very fine toothed hacksaw, bandsaw, or coping saw to cut that piece off. Be careful not to cut into where the buckle lock button is near the rail (Right controller, Step 4, Picture 2, circled in light-blue). You would also not want to disturb any part of the plastics that the rail sits in otherwise you risk it not making good interface with the switch.
Immagine
Punteggio 0
Aggiungi la tua risposta
badnatey sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 27
Tutti i Tempi: 479
