Salta al contenuto principale
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Domande Visualizza tutte
How to secure front rubber impact strip to it's bumper?
My 1985 300D front rubber trim is loosening from it’s bumper. I tried to get the clips back into place and slide the impact strip into place. Unfortunately, it will not remain snug.
Advice and directions to fix would be most appreciated.
Thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like your not getting the clip far enough onto the rubber backing . A near impossible task on dry rubber. If you were to spray the rubber with a spray lubricant like liquid wrench or wd40 you’ll find you can push the clip on further and then when you assemble your fit will be tighter. Hope this helps
Punteggio 0
Aggiungi la tua risposta
Scott Henson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 106
