Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
Data Recovery from MacBook Pro 2017 13.3" Solid State Drive
So I did the worst-case scenario of pouring an entire glass of red wine on my macbook keyboard. The machine is totally friend, but I was able to remove the SSD drive from the case.
After a lot of research, it seems like people are having a lot of trouble finding adapters or external enclosures to access to file system on the storage drive.
Has anyone had any success in removing files from ~2017 era Macbook Pro SSDs?
Wanted to ask before I go to the apple store or use a third-party recovery service. Attached is a photo of the removed drive with model number:
Macbook Specs:
MacBook Pro 13.3" - Mid 2017
Model #: A1708
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Sadly, Apple’s SSD’s use a custom connector setup, which OWC did offer external cases for the older MacBook Pro blade SSD’s, I haven’t seen any of the 16/17 Fn key systems.
The best you can do is find someone who is willing to allow you to swap-out their SSD with yours so you can then access the data making a backup onto an external drive. You might find a used system to achieve the same thing.
Punteggio 0
Aggiungi la tua risposta
Joseph Bender sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 315
