Salta al contenuto principale
Annunciato il 13 ottobre e rilasciato il 23 ottobre, il telefono al top della gamma 2020 Apple ha schermo OLED da 6,1", fotocamera posteriore tripla con LiDAR e 5G. È il successore dell'iPhone 11 Pro.
91 Domande Visualizza tutte
Problems with brightness and true tone after screen replacement
Hello guys,
i bought new display and changed it in my iphone 12 pro. After change i can’t change brightness level (when i changed it up or down, brightness level still same) and true tone doesn’t work as well. I read some articles but did not find how to fix it. I have also jcid machine to read and write data from old display to new display but i also read iphone 12 pro is not supported …. Any tips please ? And sorry for my english.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I know Qianli has a TrueTone Programmer but I’m not sure it works with the 12 series. If the device can’t communicate with the ear speaker components it can lead to a low brightness issue. Take it apart, and examine that it’s not damaged and properly connected. If it’s damaged, you can replace that assembly but FaceID will be lost permanently.
Punteggio 0
2 Commenti:
I replaced faceid from old display to the new display and brightness is now okay. Right now I would like to delete message because of non original display. JCID machine doesn't work to my iphone 12 pro because it is not supporte. It is supported only to iphone series 11. Anyone some another tip please ? :/
da
@kalis only way to get rid of that message is to either refurbish the old one or have a skilled tech transfer over the circuit chip from the old display to the new one. I wouldn't be too worried about it though.
da
Aggiungi la tua risposta
Tomáš Kalous sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 79
Tutti i Tempi: 4,939
