Salta al contenuto principale
Il telefono più popolare di Apple del 2021 è stato lanciato sul mercato il 24 settembre e ha uno schermo OLED da 6,1", un sistema di fotocamera doppia da 12 MP ed è disponibile in cinque diversi colori. È il successore dell'iPhone 12.
96 Domande Visualizza tutte
Can I replace the camera module with the iPhone 13 Pro camera module?
I want to do 3D photography, mainly for preservation and archival of actual places so future generations can view them. But I got this. The second-worst phone of 2021 (mini is worse) because it runs iOS, and because it doesn’t allow LiDAR. For me, iPhone 13 Pro is just a 3D scanner. And iOS is just a dumb firmware. So this phone is literally a 3D scanner without the 3D scanner. Can I replace the camera module with the pro one?
Questa è una buona domanda?
Punteggio -1
1 Commento
why you would do that
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sadly, no. The 13 Pro has 3 camera lenses and the 13 only has 2, so no way to fit it into the housing without modification. Additionally the camera assembly from the 13 uses 1 cable (and connection to the board) and the 13 Pro uses 2. I suppose there may be a way to modify it to work, but it would require a lot of knowledge. So I would say it’s maybe possible, but realistically, it’s not practical.
Cameras are also paired to the logic board starting with the 12 series and if I recall correctly swapping camera modules even within the same model caused the cameras to not work properly or at all.
Punteggio 4
2 Commenti:
But does the LiDAR sensor work
da
The LiDAR sensor is actually a separate module altogether and is not physically integrated into the camera at all. It even has its own connector to the board. It likely also has dedicated components on the logic board which would be absent on the vanilla 13 Pro. So. No. Not in any practical way.
da
Questa risposta era destinata originariamente a un'altra domanda.
No, you don’t. Don’t expect iPhone to be moddable.
Punteggio 3
Aggiungi la tua risposta
The Mariocrafter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 210
