Salta al contenuto principale
My smartband has been on charge for the past 3 days. Can't charge it.
My smartband has been on charge for the past 3 days. It has not been used for a long period of time. I want to use it now but its not turning on. I tried putting it on charge but no response whatsoever.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
If the smartband has not been used or has not been kept charged for a long time then most probably the battery has become depleted beyond recovery and needs to be replaced.
I cannot find a guide or video that shows how to open the smartband but have found this disassembly video of a Huawei Band (model unknown) which may be of some help.
Replacement batteries are available online. Just search for Huawei Band 3 Pro battery to get results for suppliers that suit you.
Punteggio 2
6 Commenti:
Thank you will look for guide
da
I can't seem to find the battery. Can you find one for me?
Thank you
da
@Nostalgic
There was a supplier linked in my answer above.
da
The price of shipping is more than than the battery itself.
da
@Nostalgic
Can only suggest then that you open the smartband and check if the battery has a model number printed on it.
If so search online using the model number only to hopefully find suppliers.
The model number printed on the battery that I linked only gives results for the supplier I linked and it seems like it is just a compatible replacement and not an identical replacement.
da
Mostra 1 altro commento
Aggiungi la tua risposta
Nostalgic sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 559
