Salta al contenuto principale
Gateway makes quality notebooks, laptops, and netbooks. Owned by Acer Group.
220 Domande Visualizza tutte
Is it possible to solder more flash ram, and HDD on Gateway GWTN141-10
I received cheap laptop from walmart Refurbished Gateway GWTN141-10BK 14.1" FHD i5-1135G7 2.4GHz Intel Iris Xe Graphics 16GB RAM 512GB SSD Win 10 Home Black
The laptop is great cant complain 16gb of ram speed 3200, 512 m.2 nvme, i5-1135G7, FHD IPS screen.
Is it doable to solder on board ram on this laptop motherboard?
Is it doable to solder additional two more speaker?
Is it doable to solder additional HDD drive from the HDD slot?
thx
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@yeabilo sure looks like the board is laid out for expansion. I do not see any reason not to give it a try. Of course make sure you have access to the equipment to properly solder the BGA modules. Worst case it wont work and you need a new board, best case you are going to have a kickass computer. Also check online for the BIOS to find out if it supports these mods
Punteggio 1
Aggiungi la tua risposta
simon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 811
