Hdmi output problem ps3
I have ps3 and the hdmi output do not work??? I have tryd to reset it 2times, and tryd different cable,
What can be wrong?
i can see the game if i use RBG bur not on the HDMI. i have even tryde diffrent tv but the same
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Do you have one of those all-in-one cables? In other words does your cable plug into one port on the PS3 then split off into component and HDMI? If so, you may need to search for a switch somewhere on the cable that flips between component and HDMI signaling
da
No is à regular hdmi cabel. And it in the tv.
da
Aggiungi un commento
