Wi-Fi connection after update
My iPhone is only connecting 5ghz Wifi. I can’t connect to any 2.4ghz Wifi.
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 34
Did you reboot? Also reboot wifi router at same time. Turn off phone than reboot wifi router
da stressmaster
I did. It doesn't work.
da Omar Attia
@Omar Attia can you connect to other 2.4ghz wifi? Also did you tell phone to forget the old wifi?
da stressmaster
@stressmaster Unfortunately, I only can connect to routers that support 5ghz Wi-Fi. I can't send even a hotspot to any device until I change the hotspot band to 5ghz.
da Omar Attia
It is possible the wire that is the 2.4Ghz in the phone came loose. Or the board has a chip or resistor/transistor burn out.
da stressmaster
Mostra altri 3 commenti
