Salta al contenuto principale
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
How to open the magsafe adapter brick?
Hello, i know its a hard work and it will be a lot of cosmetic damage to the brick of the magsafe, but how can i easily split the case of the magsafe, to solder the wires again?, also i'd like to do minimal cosmetic damage to the charger, thank you :)
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
These things were not built to be opened as there are really no serviceable parts. I've used a Dremel type tool with a cutting disk to get into them with minimal damage. I cut along the seams.
Punteggio 4
Aggiungi la tua risposta
Dario sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,554
