Salta al contenuto principale
The Samsung B1445A is a front-loading high efficiency washing machine by Samsung.
22 Domande Visualizza tutte
loud noise on rinse and spin cycle..what can I do to fix this
2016 samsung washer makes loud noise while in rinse, spin cycle..what can this be? and what i can do to fix this…
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Check the drive belt and maybe replace it
https://www.amazon.com/Samsung-DC66-1017...
Also if the noise is only when water is on it maybe the valve getting stuck from calcium depost and soaking it in CLR should fix this. Also run some CLR and water only and stop it mid cycle before it drains to clean these deposits out. than run 3 hot cycles empty to wash the CLR away
Punteggio 0
Aggiungi la tua risposta
adrianne campagna sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 38
Tutti i Tempi: 1,677
