Salta al contenuto principale
Lanciato a novembre 2020, il MacBook Air da 13" usa il SoC (sistema su chip) basato su ARM M1 di Apple, con una CPU octacore e una GPU che può arrivare fino a octacore. (Modello A2337 / EMC 3598 con due porte Thunderbolt 3)
175 Domande Visualizza tutte
How to replace the keyboard keys on M1 MacBookAir 2020?
Is it possible to take out 2 keyboard keys and replace them? What is the normal step by step procedure so I don’t break the keys? I saw some videos on YouTube but I don’t trust them. Do I have to take out the middle of the key on the right side, then left side, then the key will be out like this video?
https://www.youtube.com/watch?v=omYY8fly...
I want to switch the physical Z and Y keys on the M1 MacBook Air 2020 keyboard because I have a Czech keyboard and I am using English language. The Y and Z keys are opposite as I want to use a qwerty physical layout but I the macbook came with the qwetz physical layout.
Thank you
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
What I can tell you the video is the process. But getting the key cap to latch back on is a bit tricky! I would recommend you buy spare key caps as I’m sure you’ll snap the clips.
Maybe its worth the effort to find your way to an Apple Store to have them move the keys around for you.
Punteggio 2
2 Commenti:
Hey could you Tell me which kind of clips/hinge I need to search for the m1 late 2020 macbook air?
da
@tizia - This is what I have for the Intel models MacBook Pro Late 2019 - 2020 Key Caps So far they is no availability of the KeyCaps for the new M series systems.
da
Aggiungi la tua risposta
Stelios Theodorou sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 149
Tutti i Tempi: 8,003
