Salta al contenuto principale
Repair and disassembly guides for projectors.
I'm having problems with my Hdmi damage
Can an HDMI port be fixed if it's damage, I've tried everything that I know, and nothing works, I'm thinking that this is the problem. I've unplug it, it didn't come on, it doesn't even show up on the settings anymore. And when I go to the settings, it says that HDMI IS OFF and yes I use it with my fire stick for a while with know problems until now.
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi @leehampton,
What is the make and model number of the projector?
Have you visually inspected the HDMI port with a magnifying glass, for any damage e.g. bent pins etc?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If it is the HDMI port yes it can be fix by buying a new port and soldering it in. This is normally not hard to do. The hardest is finding the right port configuration. If you take the unit apart it may have numbers un it or at lease you can take a picture of the HDMI port and start looking online for a replacement. Sometimes calling the Manufacture they can tell you the part number. you will need a soldering pen(or torch and small nail) and leaded solder and solder flux.
Punteggio 2
Aggiungi la tua risposta
Carl Hampton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 396
