Salta al contenuto principale
The HP Envy 7640 is an all-in-one inkjet printer with a built-in scanner and faxing capabilities. It can be connected to your devices via Internet, WiFi, or a USB cable.
Load noise while printing and print is barely visible
While my printer is printing we hear a very load noise almost as if it is struggling or grinding. Also, when a page is printed, it's not clear seems as if it doesn't print properly and the ink is almost full so should print clearly. Thank you for any help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Those are two different issues. First the low ink issue. The print heads can get clogged and there is a clean printhead function. repeat several times until you get good ink.
second one is likely a plastic gear that you will need to find and replace.
Punteggio 0
Aggiungi la tua risposta
Krystal Torres sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 201
