Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
MacBook Pro Keyboard Backlight Not working
So, I got this MacBook from a friend, as he didn’t have a use for it anymore, it was originally a 2010 model but it got a logic board replacement, idk if that affects it. there were some problems with the RAM at first but its fixed now.
Anyway, I often do use the MacBook in low light and I normally can see the keyboard. So I use the backlight but to my surprise the thing doesn't work! It shows up as working on the OS (10.12.6) but nothing happens, I have tried it on other os's to see if it was a os problem but no luck.
I have checked the board for water damage, none.
Checked the connector in the board and the actual cable, both fine.
there haven't been any other problems with the MacBook otherwise I am just asking if it is a problem with the logic board or if its the backlight itself
Hope to hear from someone who can help
cheers ;)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Have you made sure you check the proper cable?
Review this guide Step 14 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
Is the cable damaged? I’ve seen a few torn or the latch missing.
Punteggio 0
2 Commenti:
No, its not damaged I've gone and done extensive analysis on the %#*@ thing but I haven't found anything clearly wrong with it.
da
@Aaron Official - Did you check to see if the connector has voltage? If it doesn't then that gets into the driver logic (could be a fuse as well)
da
Aggiungi la tua risposta
Aaron sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 205
