My Nextbook table will not turn on?
My nextbook will only turn on momentarily when I plug in the charger. Why will it not turn with power switch? Is the batery bad? How do you tell?
Questa è una buona domanda?
If the battery is removable, try taking it out for about 10 minutes and put it back in. If that doesn't work, try a different charging cable.
If both fixes don't work, then the battery may need replacing.
I disconnected the battery for about 5 min. with results. I will try a new chord when i get one.
Thanks.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 75
