Salta al contenuto principale
Modello A1418 / Fine 2012 / Processore Core i5 da 2,7 e 2,9 GHz o Core i7 da 3,1 GHz
212 Domande Visualizza tutte
Does i7 3770K work for iMac 21.5” late 2012?
Does i7 3770K work for iMac 21.5-inch late 2012 (iMac 13,1 model:A1418(EMC2544)).
Because someone told me K version is not supported and as a result I need i7 3770s for upgrade?
Is it true?
Thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
First lets work off of the spec sheets:
The chip you are asking about: Core i7 3770K
Your systems series: Late 2012/Early 2013 - 21.5” iMac (iMac13,1) The best you could use is I7-3770S
Here’s that chips spec sheet: Core i7 3770S
So what is different?? The TDP 77 W vs 65 W
So bottomline you need the Core i7 3770S chip! As your systems cooling and power is not designed to support the hotter running chip.
Punteggio 1
Aggiungi la tua risposta
Samsamsam Wong sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 512
