Salta al contenuto principale
Lanciato il 20 settembre, il più grande e costoso smartphone Apple del 2019 si caratterizza per il display OLED da 6,5", un sistema di fotocamera tripla e un'autonomia della batteria molto migliorata. È il successore dell'iPhone XS Max.
Will the LCD Screen Replacement Cause Board Damage?
Hello everyone, new here.
So, i have a completely destroyed iPhone 11 Pro Max that i would really like to fix up to avoid it becoming just more e-waste. Question is, i’ve done a bit of research on LCD displays retrofitted onto OLED iPhones and from what i see they usually cause board damage because of more power draw, but i wanted to find out if this magically happens to not be the case with the iFixit display.
Thanks a bunch for all the help!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
The issue is on a OLED the backlight pulls more power to give bright displays. however not all backlight leds are created equally so this is something you may want to call ifixit about.
Punteggio 0
the power ic went off
Punteggio 0
2 Commenti:
Bummer dude.
da
@adomchrisofori, is there a question in there? With just your statement we have no way of knowing what you're looking for by coming here. Are you saying your power IC died? How do you know that? What relationship does your question have with a post regarding using an LCD display on a phone originally designed for an OLED display?
da
Aggiungi la tua risposta
Tyler sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 54
Tutti i Tempi: 428
