Power button turning off but not on
My Lenovo thinkpad x230 power button has stopped working to turn my computer on after a shutdown. I can still force start it by attaching the AC when adjusted in BIOS but clearly not ideal when there isn’t a power source available. The power button does however work to shutdown or sleep the computer once on so I don’t understand the issue.
So far I’ve tried a few methods on the internet - taking the battery out, holding the power button for 30 seconds, putting the battery back in but nothing and given that the button still works to power off it isn’t a problem with the plastic button pressing down underneath. The battery is also pretty degraded, only holding 20% of its original capacity so I don’t know if that could be the cause.
I could buy another keyboard for £30 but I’m not even sure that’s the problem so don’t want to waste money if I might as well get a whole new laptop. I’ve also been trying to remap another key to the power button but hasn’t worked. Any help would be much appreciated, thanks
Questa è una buona domanda?
Hi Tom,
Have you tried taking the battery and just use the charger?
Does the power button work now? If it works then the battery may be the problem.
When you get it working, as you mentioned in your question, do you shut it down using Windows Shutdown?
da mike
Hi Mike, thanks for the reply. I have set the BIOS to automatically turn on when the charger is attached so I cannot test to see if the power button works before it switches on! I also don't want to change this as I may not be able to power on the computer all then. I normally use the windows shutdown once on but I have tested to see that the power button still works to put it to sleep or shutdown. The battery capacity seems most likely so will order a new one and see if the problem still occurs. Thanks, Tom
da Tom
