Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
Power button not working - randomly
Hi,
The power button of my iPhone SE (2016) stopped working 2 weeks ago, out of nowhere. No shock or anything. The phone had never been opened.
I checked the software, hard reseted, updated, reinitialized, nothing fixed it.
It was time to fix the hardware. I ordered a new flex cable and changed it. Didn’t work either…
Just to be sure I didn’t break the flex cable while replacing it, I got another one. Before replacing it again, I checked first if the button worked just by connecting the flex cable and pressing the button. It worked! So I took the time to replace it again, and it worked once the phone closed.
Sadly, there is a next. A week later, not working again!
Out of curiosity, I just connected the flex cable I thought I had broken, and the button works!! So I suppose the flex cable in the phone works as well, and the problem is somewhere else
I noticed that when the button doesn’t work, I can’t turn off/on the phone. When I try to turn it off, it turns on right away and got stuck in an infinite boot loop until I connect it to a lightning cable
Any idea what’s going on!?
  • When the flex is in the phone, it doesn’t work, or for just a few days
  • When the flex is connected on the fly, it does work
  • Infinite starting loop when the button doesn’t work
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Some pins on power button connector have been shorted to ground so when the whole button shorted to ground(broken) causes loop why? Because power button is connected to pp_1v8_always(main power supply to boot a phone) and power button acts as a trigger signal,so if it shorted CPU will do loop because PP_1V8_ALWAYS is shorted
Try to measure diode value on power button
Punteggio 0
Aggiungi la tua risposta
David sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 427
