Salta al contenuto principale
Authorized Homelite dealers nationwide, including lawn and garden and building supply stores, sold the blowers from October 1994 through December 1996 for about $200.
Why is no fuel getting in the cylinder an not starting
Is there any way any one has a manual for it
Questa è una buona domanda?
Punteggio 1
3 Commenti
Hello snsjss
da
@walker34 your blower a Homelite backpack blower (bp250)? If not we need more info about what engine it has etc.
da
Plugged gas line, fuel filter, fuel valve or carburetor gummed up.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
change the gas line and remove the carburetor. use carb cleaner and remove everything to pieces and blow the cleaner in every hole. the float bowl injector is the screw that holds the gas reservoir of the carb to the engine. this is usually the culprit and needs to be cleaned.
Punteggio 1
Aggiungi la tua risposta
Ethan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 872
