Salta al contenuto principale
La versione con solo il Wi-Fi dell' Apple iPad Air, numero modello A1474. Disponibile nei colori grigio siderale e argento, ha un processore A7 custom ed è disponibile con memoria da 16, 32, 64 o 128 GB.
299 Domande Visualizza tutte
What should I use instead of an iOpener to remove the battery?
I’m attempting to do a display replacement and battery replacement on an iPad Air, and have just gotten to the step where I need to use an iOpener to remove the logic board and battery.
I don’t have an iOpener. I was only able to get this far into the repair without one because the display was already falling off from poor adhesive the last time a repair was performed on the device.
Instead of an iOpener, could I use a hairdryer or something?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Yes, you could use a hairdryer. I sometimes use my mom’s neck heat thing and that works perfectly after putting it in the microwave for 3 minutes. What I would not recommend doing is putting it in front of a space heater as this could damage the device. Hope this helps!
Punteggio 0
Aggiungi la tua risposta
mjesticfalco sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 108
