Salta al contenuto principale
Home button not working
Hi,
I purchased an iPad described as “badly cracked screen but everything else working perfectly”
When I received it I discovered the home button wasn’t working. I wasn’t too worried as I noted a hole in screen above home button ribbon cable, and I could just order a screen with a button.
After changing screen I have found it is still not working!
Q1. Could I test it with a home button from an iPad 7? Or would that cause damage/not work anyway? (I ask because I have one that I could try)
Q2. If it's not the home button, how hard/easy would it likely by to have problem diagnosed and fixed? The connector looks fine to my eye.
Any advise on course of action would be appreciated
Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You might have ordered a digitizer with a home button for an iPad Air pre-installed. These are common because the Air does not have touch ID. You have to order a home button specifically for an iPad 5.
Punteggio 0
1 Commento:
Thanks for that, I think you are right.
I ordered an"iPad 5 digitiser with home button flex" but pretty sure button is for Air.
Annoying, but a relief!
da
Aggiungi la tua risposta
Chris Reader sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 77
