Salta al contenuto principale
Il Samsung Galaxy A71 è uno smartphone Android prodotto da Samsung Electronics come parte della serie Galaxy A. È stato rilasciato nel gennaio 2020. Versioni: SM-A715F/DS, SM-A715F/DSN (Globale), SM-A715F/DSM (Russia).
Screen Issue Yellowish Pale Bright
My Samsung Galaxy A71 (Not 5G one) have a screen issue, The screen flickering and then become Yellowish and Brigther, Everything that usually black it become brown (such as Youtube Blank Space that doesn't fit / AOD / Samsung Logo when restart) First it's change from normal to yellow and then it's become permanent yellow full screen, flickering to normal sometimes or brighter and darker version. Everything looks pale and bright some sort of contrast maybe? I've try safe mode but it's still the same. I'm asking first because I don’t want to factory reset.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
It sounds like you have either a bad display or an improperly connected display flex. Have you had the phone repaired recently?
Punteggio 0
2 Commenti:
No I haven't repair my phone before.
da
In that case, you could take it to a repair shop so they can take a better look at it, or you could try replacing the display. However, with Samsung's phones, you have to go through the back to replace the front, and sometimes the back cover can break if you aren't careful.
da
Is there a fix for this issue? I have this issue rn. Usually screen turns black whenever i go through something black or when screen is hot
Punteggio 0
Aggiungi la tua risposta
Gunsøu sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 19
Tutti i Tempi: 1,291
