Hard shell for the screen cracked
Just found out my laptop was cracked,
Please help.
Thanks
Questa è una buona domanda?
Please help.
Thanks
This was a common issue in this series. The polycarbonate case often cracks at sharp inside corners like this.
Using some 95% or better isopropyl alcohol flush out the gap of any junk using a syringe with a small needle and a few short blasts of can’ed air. Then use DAP-RapidFuse Clear All Purpose Adhesive should be enough to hold things. Make sure you have a way to press the two sides together once you get the glue in (move quickly) Don’t touch the area and hand holding is not good enough.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 55
