Salta al contenuto principale
Modello A1419 / EMC 2806 / Fine 2014 o metà 2015. Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (ID iMac15,1); EMC 2834 fine 2015 / Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (iMac17,1) Tutti con display Retina 5K.
573 Domande Visualizza tutte
Does Late 2015 iMac 27" (SATA model) come with Blade drive socket
Hi, just a quick question I have
Does the Late-2015 iMac 27” (SATA model and not the fusion drive model) still come with the blade drive socket to plug in PCIe/nvme drives?
I have done ton’s of upgrades to the fusion drive models installing NVME drives but just wondering if Apple also supplied the standard SATA models 27” iMacs with the socket/port on the logic boards or only on the fusion/SSD drive models?
Thanks kindly :)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The SATA cable header is present on all of the newer ‘21.5” & 27” Thin Series’ systems. Only the the PCIe/NVMe connecter and support components are missing on some of the 21.5” models, surprisingly it is present on all of the 27” models.
Here’s the needed cable iMac Intel 27" 5K (Late 2014-Mid 2015) Hard Drive Cable
If you have thin fingers and dexterous you might be able to plug the cable in without pulling the logic board. Other wise you’ll need to pull it forward
Immagine iMac Intel 27" 5K (Late 2014-Mid 2015) Hard Drive Cable
Prodotto
$19.99
Punteggio 2
1 Commento:
Perfect, taken the logic board out and the SATA model Late-2015 iMac 27" sure had the port. Thanks kindly for ur reply.
da
Aggiungi la tua risposta
Adrian sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 355
