Hi just follow the path that I'm providing, first unlock bootloader in your mobile phone. and then you an install TWRP custom recovery.
Next you need to download Magisk. you can go to XDA Magisk release thread and choose the recent version of it and download it.
After that you can connect to PC -> From the mobile phone screen you can select the " Transfer File " Option.
if your mobile doesn't open automatically just navigate where it mounted and copy the magisk zip file from the download folder of your mobile. then remove your mobile safely.
next you must reboot your device. after that process you'll se a screen with android mascot and menu with start options. from this you must select recovery mode.
Then TWRP will be reset once more. in here you may input your password to access storage.
then select Install when you get TWRP menu. navigate to copied magisk and select the zip file.
After that TWRP will provide information in magisk zip and the ability to install the other zip files. Once your ready you can swipe the blue slider to begin installing magisk.
from this step normally TRWP will guide you the installation of magisk to your system , once the whole installation is completed a notification will appear to reboot your system at the bottom of the screen.
So use must click the notification message and reboot it. After that process your mobile will be rooted and run magisk. if you need to check the progress open magisk manger in your apps as follows.
Hope you got the necessary information and if you got any issues you can connect me . all the picture right goes to magisk
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
