Is the screen replaceable on the iPhone 13 pro?
I heard that if you replace the screen on the iPhone 13 that Face ID won’t work anymore, is it true?
Questa è una buona domanda?
Yes at the moment this is true. Even if you transfer the components across from the screens it will still not work. The front camera will not work properly either.
Hopefully apple might fix this in the next software update.
The only way to get Face ID back after a screen replacement on the 13 is to transfer one of the ICs on the back of the screen by micro-soldering.
Edit: Apple is no longer disabling Face ID after screen replacements on the iPhone 13 series
Currently, on the iPhone 13 Series, when replacing the new screen, you can still use Face ID as usual. However, the technician will have to move the old display IC to the new screen. This helps the iPhone after being replaced without the "unknown components screen" message.
Although it is possible to use Face ID normally, the current iPhone 13 series after replacing the screen will not have the TrueTone function as on the old screen.
You can check out more of my posts here: Thay màn hình iPhone 13 Pro Max
This post is not more relevant, since Apple changed the software. Face-ID won't be disabled after a screen replacement.
Can anyone confirm if replacing an iphone 13 pro screen(original from a donor phone) running IOS18 will enable to restore True Tone functionality and auto brightness
Yes, you can restore True Tone and auto brightness when replacing the screen on an iPhone 13 Pro (even on iOS 18), but only if you transfer the original screen data (EEPROM) to the donor screen. Just installing a genuine screen from another phone won't bring back True Tone on its own — the phone needs to "see" the original screen's calibration data.
You'll need a screen programmer tool like the JC V1S or QianLi iCopy to read the data from the broken screen and write it to the donor one. Without this step, True Tone stays disabled, and auto brightness might behave oddly too.
If it's done through Apple or an authorized service provider, they have tools to pair everything properly. Third-party repair shops can also do it if they have the right tools.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 53
Tutti i Tempi: 2,448
4 Commenti
Yes at this time
da blake.preston
it is true, only apple can pair the new components. You and third parties can not.
da danumba1marce
iPhone 13 Pro- Replacing the screen with an original apple screen taken off a Donor phone will lose or retain Face I.D.?
da Malcolm
@malcolm34057 There was a limited time period in which iOS was killing Face ID when the screen's serial number didn't match that of the phone, but after much public outrage at such a tactic, they relented and removed that matching requirement from the latest iOS versions.
As long as you make sure to update your iOS, Face ID will still work after replacing the screen. You will, however, get a "non-genuine" part pop-up warning for about a week though, whether it's a genuine Apple screen or not unless you transfer the IC that @primalphoenix was talking about in their answer.
da Jerry Wheeler
