Turn signals not working
My turn signals aren’t working on my 2001 Cherokee. I replaced 2 bulbs and checked all the rest. When I force the right signal it blinks once then nothing
Questa è una buona domanda?
@lbrannock11 check the blinker relay because that could be what is causing this. Not a terribly complicated job. This video makes a pretty good job of showing you how to replace it.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 380
2 Commenti
Changing the relay lit up the signals so I can manually make them work but it stopped my hazards from working. This is as far as I can go as I can’t take off the steering wheel
da Lisa Brannock
@lbrannock11 you made sure that you have the proper bulbs in your lights? Some of the multi filament lights can cause this if they are the wrong type.
da oldturkey03
