Salta al contenuto principale
Informazioni sulla riparazione per tutto ciò che mantiene l'esterno di casa tua ben curato.
Garden shredder does not stay on
I have a garden shredder al-ko h2200. The day i bought it, the guy who was selling it tested it on my eyes and everything went great. Next day i turn it on in my place and it doesn't stay on. There is this switch that is supposed to stay on but it doesn’t and i have to keep holding it to have it keep working which of course is undoable. I opened it and cleaned several times, there is not much to brake or change there, i have no idea what could be the issue.
Please help!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Maja Borkowska either you have a bad rotary switch or you have something blocking the blade. Double-check everything.
Complete manual here AL KO H2200 Shredder
Punteggio 2
2 Commenti:
The blades are running fine, so i suppose it must be a bad rotary switch. How can that be fixed? Do you think it's some electrical problem inside?
da
It says something about a safety switch in case of overload and I wonder if that is what causes this. Ultimately time to take a look at the switch and possibly replace it with a new one. That at least will not be too complicated or expensive. Any good rotary switch should work for that.
da
Aggiungi la tua risposta
Maja Borkowska sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 480
