Salta al contenuto principale
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
20 Domande Visualizza tutte
Not starting when top screen is in position
I had the ‘turning on but sound popping’ problem which I thought I fixed by disconnecting the faulty IR sensor from the device.
However now the problem still exists but only when I put the screen in the maximum stance.
When I leave the topscreen in the first position (like when the 3DS is sitting on my desk) it works perfectly. But with clip the screen 1 position further (like you would do when you have the console in your hand, it turns off again!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
I don’t see thosr console too often at the shop, but I have a vague memory of having one of those consoles that had an issue with the screen flex cable that would get compressed when the top screen went into it’s last position.
I don’t recall of we had to replace the screen or only reposition the flex cable.
I hope this give you a trail.
Punteggio 1
1 Commento:
It's very likely, I've heard of similar cases and indeed it seems like the screen ribbon cable is being stretched. I've reseated it a couple of times but no progres....
I might delve deeper but am very scared of breaking those thin cables or having to fiddle with the hinge to put cables through it.
Thanks
da
Aggiungi la tua risposta
yaboi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 71
