Very high leak rate on report screen
I get very high leak rates 40 to 70 L/min indicated with no mask seal alert and no warnings. Mask,tank,and tube all check good with no leaks
Questa è una buona domanda?
i have same problem i fix it by replacing the mask and program the cpap with the new mask .. it works.
I have the same issue. I’m replacing the first internal gasket before I try the harder to replace air pump gasket. https://www.directhomemedical.com/resmed...
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 477
