Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
screen black + chime every 10s, way to cast to screen?
I have an iphone 4, gsm, screen is black and when plugged in, vibrates after a few minutes, then does the charging chime every 10s or more. i tried the home button and power button restart, and it shows on my computer just fine, abeit it has a passcode so i cant get into it anyway. the screen is cracked to !&&* but it worked like that, any way to see whats on the screen via casting to something with a cable or the like? Id also like if someone could tell me what the issue is thats causing the no-response and chime. i have a screen coming the 1st of october, and if a new screen doesnt solve it, ill try anything.
TLDR: read first sentence, need to cast to something to see screen if possible, screen is almost gone but new one will be here in a month. what could be causing my issue with the chime and can i cast the screen to something?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would try this adapter: https://smile.amazon.com/dp/B07GSX59TP/r...
Punteggio 1
Aggiungi la tua risposta
Hecktor Chaboygan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 31
