Salta al contenuto principale
Un piccolo aggiornamento del MacBook Air di fine 2019, con lo stesso numero di modello (A1932) e numero EMC (3184). Questo modello ha uno schermo True Tone e una batteria leggermente revisionata.
101 Domande Visualizza tutte
Audio Jack and Touch ID Not working.
Hi all, I am having this problem with my MacBook Air 2019 Retina. I replaced the Screen and after the screen replacement, my Touch ID and the Audio Jack stopped working. The internal speakers work perfect but the problem is the system keeps crashing with a Kernel Panic statement that relates to the Audio Jack board.
I am thinking of replacing the Audio board since I am assuming the faulty board is making my Touch ID also not working. I see the cable to the Touch ID is connected on the Audio board. Any suggestions.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yep! Thats what I would do! MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard And here’s the guide: MacBook Air 13" Retina Display 2019 Audio Board Replacement
Immagine MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard
Prodotto
$119.99
Punteggio 1
7 Commenti:
Okay. Thank you.. I will let you know when I am ready to order
da
hi, did replacing the board help?
da
@kirillseme40278 - In this case it did!
da
earned jack and touch id?
da
@kirillseme40278 - Please expand what you mean.
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Steven Kobby sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 160
