Light doesn't stay on when clock reaches actual alarm time
My clock has an issue where the light comes on during the build-up to the alarm, but turns off once the clock hits the actual alarm time (but demo mode works perfectly). It usually would keep the light on for about 90 minutes after the alarm time unless turned off, but it stays off during this time as well. What’s strange is that the clock display is brighter, like the clock knows the alarm is happening, but the actual wake-up light is not on. Sometimes, unplugging the clock for a few minutes and plugging back in can fix this for a few days, but other times that doesn’t work. It’s very frustrating and has made the alarm completely unreliable.
Also, occasionally I get the random clicking sound like it thinks the buttons are being pressed when they’re not, as mentioned in a question by another user. I’m not sure if these are related or not.
As stated, I’ve tried unplugging and plugging back in, I’ve also tried unplugging and holding down the light on/off button for 15 seconds as suggested in another comment. But regardless, the issue eventually comes up again. Any help is appreciated!
Questa è una buona domanda?
3 Commenti
@Tessa Huffstater Do you know how to take the alarm clock apart?
da Andrew S Condividi
No, I don't, I didn't try
da Tessa Huffstater Condividi
Okay, I'm an experienced tech engineer, and after reading the thread I see no solution and no good insight about the cause, so I tried to dive deeper with this issue and make some studies. First, if you set up a new wake-up time right after the light fails to stay, for at least half an hour apart, it will work and stay for 1,5h after, then smoothly fades out. The most interesting thing if you set the wake-up time to the evening one, around 20.30 or something it is still wakes and stays! But as for the morning time it fails.
I tried to shift it's own clock for 12 hours, and set up two alarms, for 8.30 and 20.30. So the clock thinks it's morning when it's actually evening. And it still fails in the real morning and works and stays in the evening!
The only significant difference between these conditions I can conclude is ambient lighting (it has the light sensor which lets it know how bright the display should be), the sound sensor (it stops the sound if you make noise while it's singing), and temperature.
da Сергей Сафонов Condividi
