vertical lines on my display
Hi All,
I have a couple of vertical lines on my display - the number of lines are growing slowly(6 at the moment)
I mirrored the display on my TV , no lines there.
Is it the display panel itself or could be the wire connects the logic board to the LCD?
Or something else?
Thanks.
Update
I did lot a research on the web, and figured there are lots of people who suffered from the same issue.
There are two possible solutions:
1. You buy LCD panel online and take it to a pc shop and pay for repair.
2. Make a lots of phonecalls to apple and if you pushy enough might get lucky and apple might fix it for you for 30-50$. They changed mine LCD. Said there was a factory defect on some of the LCDs for the G5s.
Give it a try! Good luck
Update 2
Here's a useful thread to check.
Questa è una buona domanda?
4 Commenti
Adrian
I had open mine before they fixed it, i had lg/philips lcd panel in mine. I think the brand does not mater if it fits, have the required connectors and matches the resolution
You can check the following links:
these are pricey a bit:
http://mac.macrecycling.com/displayscree...
http://www.welovemacs.com/6613626.html
this is the cheapest one:
http://www.dvwarehouse.com/Apple-LCD-Dis...
Hope that helps..
Tamas
da Tamas
Great, can you tell us under what repair program or recall that Apple did this so that your answer could help others?
da mayer
Nice updates on your question Tamas! I actually have this problem on an old Alienware right now. I'm hoping it's just the display data cable, but I'll open it someday soon.
da Matthew Newsom
Thank you
lines are multicolours and they are fix at the beginning and then start changing colour so it looks as they are moving but the position is always the same in the right-middle. I have a new LDC from Apple becouse I alredy had a pixel break down, I still don't understand exactly what's going on
da Robin
