Salta al contenuto principale
The Polaroid Cube is a splash-resistant, shockproof, and mountable camera that takes 6 megapixel pictures and shoots videos in 720p or 1080p HD.
Memory card not coming out
Memory card won’t come out, tried pushing it to pop out but won’t work. Tried grabbing it with tweezers but it won’t come out
Questa è una buona domanda?
Punteggio 0
1 Commento:
Had the same problem. When I finally got it out I put a piece of "Crystal Clear" Scotch tape on it as a pull tab so I never have this problem again. This is a HUGE help, and I use the tape tab all the time.
da
Aggiungi un commento
1 Risposta
Have you tried using some sturdy tweezers or a metal pick to remove it? The memory card might be pretty stuck, but it should come out. Be careful not to damage the card though —- SD cards can be pretty fragile.
Punteggio 0
Aggiungi la tua risposta
Guest sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 327
