Salta al contenuto principale
The Apple Extended Keyboard is a USB-A extended keyboard with an aluminum body and a numeric keypad.
Mac keyboard typing wrong letters
hi there!
I’ve got issue with my extended mac keyboard. As an exemple when i’m punching the letter P, the O also appear.
It also doing it with the L and the ;
I noticed that these keys are alongside on the keyboard.
Someone have a solution with this issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You must have had a spill into the keyboard so the signal lines are damaged shorting out.
Think of it this way… Your keyboard is a grid of horizontal and vertical lines. The point where they cross is the Key shorting them to make the given signal to the keyboard encoder. This is all done within the keyboard.
Sadly, Apple does not design its newer keyboards as serviceable. Time for a new keyboard ;-{
Punteggio 0
1 Commento:
Thanks a lot for your answer Dan! :-)
da
Risposta Più Utile
Replacement required
Punteggio 1
Aggiungi la tua risposta
Jean-François Duguay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,393
