Proximity sensor, lightning port and cellular not working all at once.
Update: I disconnected the earpiece part of Face-ID and run the phone without it everything else works fine now. I would probably try replacing that part to regain speaker functionality.
One day my iPhone X started to have a lot of issues at once:
- Boot-loop if battery is empty, with a new battery I got it to boot and backed up my data but there are other issues
- Lightning port doesn’t work most of the time and even when it shows charging, it doesn’t really charge. A wireless charger works but very slowly.
- iPhone reboots randomly sometimes after only 3 minutes and sometimes after a few hours.
- Face-ID doesn’t work after some digging I found out the proximity sensor doesn’t work.
- Taptic engine doesn’t work, could this be due to a faulty lightning connector assembly?
- Cellular doesn’t work
- The first panic-full log says: “AOP NMI FIQ - pc=0x0106bb9a - rtk_ep_work(0) - watchdog timeout: No response in over 20 sec.“
- All other logs say: “sleep/wake hang detected“
From my understanding, the first crash and Face-ID issues could be due to a faulty earpiece flex cable and the other reboots as well as lightning port and taptic engine issues could be due to a faulty lightning connector assembly. However I still have no explanation for why cellular doesn’t work. Finally is it possible that 2 different flex cables fail at once? Is a fault in the logic board more likely?
Questa è una buona domanda?
3 Commenti
The Taptic Engine IS in the same assembly as the Lightning port, so there could be a loose connection on that board causing some of the problems. Flex cables can also break easily if you've opened up the phone. Finally, your logic board could be faulty. Can you start by making making sure the Taptic Engine is screwed into place, the Lightning connector doesn't have any dust or debris in it, and the cable connecting the lightning port assembly isn't broken or torn and does not have any exposed wires?
da Andrew S
@andrewsawesome all of these issues happened before changing the battery. I reopened my phone and tried one more thing: disconnected the earpiece speaker and front sensor assembly entirely and now everything works: lightning port, taptic engine and cellular. I would probably try replacing it entirely to regain speaker functionality but this is surely an issue with that part and not on the logic board side right?
da Ali Bibi
@bibii I can't say for certain, but from what happened it seems like there is a short or other problem in that assembly. However, save that assembly just in case it's fine, as you may not be able to restore Face ID functions otherwise.
da Andrew S
