Salta al contenuto principale
Charging station for the Dualsense PS5 controller.
How to remove the white side plates
The dualsense charging station has white side plates like the Playstation 5 console. I want to paint them black, so I was wondering if there was a way to remove the white plates. There are no visible screws. The whole thing seems to be glued together.
Questa è una buona domanda?
Punteggio 2
1 Commento
did you ever find a way?
da
Aggiungi un commento
3 Risposte
Risposta più utile
If you turn the charging station upside-down, on the bottom plastic you will see two edges which connect to the inside side and top plastic which is one moulding. Pry the bottom plastic off (it's just clipped) and then undo the screws and the white side plastic comes off.
Punteggio 2
See my teardown over at Dualsense Charging Station Tear Down Guide
Punteggio 2
So if you want to take the sides off your PS five you want to hold the PlayStation button press down and then up and then it’s off
Punteggio 0
Aggiungi la tua risposta
Sulakshan Rajaratnam sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 13
Ultimi 30 giorni: 60
Tutti i Tempi: 1,945
