Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
590 Domande Visualizza tutte
I think my 2010 15" MBP logic board is fried
I pulled my laptop out of my backpack a few weeks back and it would not power up. It’s a mid 2010 15” Unibody i7 2.66 GHz with 8GB RAM and two SSDs (1.5TB total).
When I press the power button:
  • I don’t hear fan spin up
  • The screen backlight does not turn on.
  • There is no boot chime
  • The status indicator light on the front of the top cover does, in fact, turn on.
  • Magsafe turns green and then amber when battery is connected. When the battery is disconnected it is only green.
With the case open, I have been able to get the fans to spin by disconnecting the battery and first pressing the power button, then plugging the magsafe in. I don’t think I’ve been able to reset the PRAM and SMC successfully as it doesn’t seem to get past post. Also, I hooked the laptop.
I’m not a logic board repair person by any means, but I’m thinking maybe the thermal paste on the GPU and CPU needed replacement and those components may have overheated. I noticed the laptop got pretty warm before this failure happened.
Any and all help is appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
After looking up some more solutions on the web I ended up baking the logic board in the oven and that fixed it. I think it was the GPU and it needed a reflow. It was down for weeks and I’m typing this message on it now. Thank you very much for the help.
Punteggio 0
Risposta Più Utile
Go for a spontaneous restart. Disconnect the mag-safe then the battery from the logic board. Press and hold the power button for 10 seconds. Reconnect the battery then the mag-Safe. It should restart on its own.
Punteggio 2
1 Commento:
Thank you for the help.
da
Aggiungi la tua risposta
JDiddy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 53
