Salta al contenuto principale
La versione allargata del decimo telefono di Samsung della sua serie top S, presentato nel febbraio 2019. Dotato di Android 9.0 (Pie).
20 Domande Visualizza tutte
Screen replacement. Is it possible to just replace the glass
I used the picks and suction cup to seperare the glass from the main body. And the shiny part came off now i cant see the screen. I think i screwed up havent replaced amoled before. Its likr a technicolor shade for both the glass and the main body
Questa è una buona domanda?
Punteggio 0
5 Commenti:
I have seen a few videos that say it is possible. One technique is Quick deep freezing the phone. this is a very expensive freezer. So probably not a DIY option. Some say possible with Dry ice. And then there is Heat and a very thin piece of metal that you slide between the digitizer and the glass. I have the tools to do this. And going to try it on a note 8 soon. but I have a full screen to replace it with in case it does not work. Also seen a lot of bad stories trying the above methods. So not sure how dependable they are.
da
@gkjarhead what's it called the tool. Thanks
da
OCA Blade is what it is called. And here is the website for it https://expertcelldiy.com/products/samsu...
da
@idontfixitwell Remember this is very risky. And my understanding is that most do NOT end in success unless you have a Lot of experience doing it. I plan on trying it but have a seperate full screen I purchased just in case I mess it up.
da
Aggiungi un commento
1 Risposta
OLED displays are very difficult to do DIY glass only repairs on. At this point, you’ll need to order a whole screen assembly.
Punteggio 0
Aggiungi la tua risposta
Adrianj sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 576
