Salta al contenuto principale
Guide di riparazione e manuali di istruzioni per il Lenovo IdeaPad 330-14AST. Il Lenovo IdeaPad 330-14AST è un portatile progettato per un uso occasionale.
Fix Mbr showing error
Immagine
As above question my problem is same
But it is showing this error
Questa è una buona domanda?
Punteggio 0
1 Commento
Which version of Windows are you using?
Which error message did you get that prompted you to try and fix?
da Condividi
Aggiungi un commento
2 Risposte
Risposta più utile
Type ''BOOTREC /FIXMBR ''and hit <Enter>.
This command will attempt to fix any corruption issues with the master boot record. If all goes well, you should see The operation completed successfully.
Next, type BOOTREC /FIXBOOT then hit <Enter>.
This command will attempt to write a new boot sector on the hard disk if Windows detects damage. Usually, this happens in cases where an older version of Windows was installed, or a non-compatible operating system such as Linux was installed.
If you are seeing an error such as Boot Manager is Missing, then the BOOTREC /RebuildBcd command might be able to fix it. This operation can also restore boot entries for older versions of Windows if you have a dual boot configuration.
If BOOTREC /RebuildBcd does not work, then Microsoft recommends you back up your BCD (Boot Configuration Data) store, then run the BOOTREC /RebuildBcd command again. Here is how you do it. Type each command then hit <Enter>:
·                     bcdedit /export C:\BCD_Backup
·                     c:
·                     cd boot
·                     attrib bcd -s -h -r
·                     ren c:\boot\bcd bcd.old
·                     bootrec /RebuildBcd
Punteggio 1
You sure it's not
fdisk /fixmbr
Punteggio 0
Aggiungi la tua risposta
Satyam Singh sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 66
Tutti i Tempi: 657
